I Need Help!!
    I Need Help!!
    anyone know the reason why if i have the key in the "ON" position everything is dead, like none of the dash lights go on, and then when i turn it to the start position it "starts" but wen i let it go to return to the "ON" position it just dies. Anyone know what could be causing this??
    hmm thats kinda strange that it starts after u dont have power at the ON position. does ur acc. position work? if u click the key once, can u listen to the radio? the only thing i can think of for this is that your ignition has gone out on u.
      the "on" contact on the switch is bad/corroded.
      ILBB
      People I have dealt with in this board- Smseagren83,d112crzy, Idrivealude, aznpnoyracer, wed3k, dinertime, HF22T, MRX, Dc2lewd, yeamans17, bruno8747, tn_accords, king james, starchland, yardiexd40
      Mk3 Supra Member #2
      Originally posted by DarkShadow707
      The world needs to be reset.
        would you happen to know if an ignition switch from a 5th gen accord would work??
        Also is the ON position like a remote wire?? i know this may sound stupid but for example a car stereo amplifier, if the remote wire has no signal then the amp wont turn on, is that kinda the same i idea??
          basically when ur key hits that position it turns on or "relays" the power from another source to that point. your ignition switch is bad, u can buy it for about 40-63 bucks at local stores.
          maybe a 5th gen one will fit, but u got to see if the mounts fit right.
          Retro!
          Hater
