anyone know the reason why if i have the key in the "ON" position everything is dead, like none of the dash lights go on, and then when i turn it to the start position it "starts" but wen i let it go to return to the "ON" position it just dies. Anyone know what could be causing this??
I Need Help!!
the "on" contact on the switch is bad/corroded.
ILBBPeople I have dealt with in this board- Smseagren83,d112crzy, Idrivealude, aznpnoyracer, wed3k, dinertime, HF22T, MRX, Dc2lewd, yeamans17, bruno8747, tn_accords, king james, starchland, yardiexd40
Mk3 Supra Member #2
Originally posted by DarkShadow707The world needs to be reset.
basically when ur key hits that position it turns on or "relays" the power from another source to that point. your ignition switch is bad, u can buy it for about 40-63 bucks at local stores.
maybe a 5th gen one will fit, but u got to see if the mounts fit right.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
