No this isnt no how do I drive a manual thread. When I drive and shift to another gear I can change gears with out depressing the clutch in. No that didnt come out right....I can move the stick out of first and into second with out depressing the clutch but still have to depress the clucth to go into gear I know that is natural, but should I be able to pull it out of gear like that??????
manual shifting problems
I dont think your suppose to be able to pull it out of gear like that. There is play in there but not enough to pull it out. Does second still engage when you pull it manually? Something sounds wore out in the tranny but i could be wrong.
Originally posted by halfaznit does that in all gears I was just wondering cause now I learned a new way to drive my cb7 and i shift faster.......dont ask me im backwards but yeah under high load hard to yank out under low load easy your right. Just wanted to see if i was crazy or not
in every single manual transmission car ive driven you can pull the car into neutral without depressing the clutch. it is normal.
dont do it under load, thats bad for it.
and if you didnt know, at a certain RPM you can actually put it back into gear without depressing the clutch. its not good for the tranny but you can do it.
race cars like Winston (nextel ) cup and busch drivers only use their clutches when starting and stopping. during the race, shifting never involves the clutch
