Computer swap
    Computer swap
    Can you use a computer from a 92 accord 5 speed into a 92 accord automatic?
    Does the transmitions have anything to do with the computer.
    1992 Accord EX version 1.0 before
    1992 Accord EX RHD version 2.0 after
    right hand drive conversion
    I believe you'll need an automatic transmission ecu for an auto cb7
    many interchangeable... but need to be for the same transmission (auto or manual)
      hmm... i think
      ECU is swappable...but not TCU
        Originally posted by 93EXaesthetic
        hmm... i think
        TCU is only for autos. later.
        Avoiding dirt at all costs
          So I guess nobody is 100% sure that it can be done.
          So i have no choice but to try it. If anybody knows if it cant be done,please let me know before i go through all the trouble.
          Thank you
            Thank you
            Pretty sure it's the same ECU, so why would you want to do this, I'm not seeing any chance for improvement here?
            Honda-Tech Username: Lostcb7
            The cb7tuner.com OG.
              Check this link out and it will explain everything
              http://www.cb7tuner.com/vbb/showthread.php?t=37423
                I gotcha, sorry to hear about that. Yea I think it should work, why don't you throw it in and find out for us
                  I suggest you ring up your local Honda Parts Dealer and find out the Part Number of The Manual ECU and The Auto ECU for that Specific Model and see if they Match!! That is the easiest way of knowing what parts are interchangeable with other Honda Models.
                  **EDIT**
                  I checked out RockAuto.com for part numbers and here is what I have determined.
                  ECU - Manual Transmission|Federal Emissions = OEM Part# 37820-PT3-A04.
                  ECU - Auto Transmission|Federal Emissions = OEM Part# 37820-PT3-A55.
                  I also noticed there are different OEM Part# for Different U.S. Emission Laws. You may have to throw that into the equation as well.
                  Fortunately Here in Australia our Emission Laws are Universal and not State Bound. Must be different in USA. Bloody Do Gooders!!!
                    last 3 digits maybe that specific part number and last 3 digits on all are different? or prolly not i dont even know
                    rollin on em twankiez
                      you can
