Hi,
Here's the story so far. I've got a stock P13.bin file from the WIKI library @ PGMFI.org and I downloaded an import script from uberdata's forums that allow you to import the ign tables from this base p13.bin. The fuel tables of the P13, at this point, can't be read. However, I'm currently working on fixing that problem for all of us and I had some questions about uberdata.
1) Does each ECU has different RPM/VACCUM values on the independent axies? ie. the 1st entry in a low_fuel table of a P13 have the same VAC/RPM as the 1st entry in a low_fuel table for a P28?
2) If Yes to Q1, does anyone know what the independent axies values would be for a P13?
3) Does anyone know if uberdata is under the GPL (aka. open source)? I could have sworn I saw that somewhere, and no I'm not talking about the scripts.
Thanks guys for any input,
TheTempest
TheTempest
