hey guys i have a small problem i was driving my car earlier this week with no problems and just the other day out of nowhere i noticed my car was cranking over slower than normal but still starting and running fine. then i went to start it an it doesnt even crank, weird thing is all electrical components work fine and i tried jumping the car with no avail. your help would be much appreciated thanks! P.S. i tried searching but i counldnt find anything like my problem.
doesnt turn over, Help!!
This topic is closed.
Sure there are quite a few threads already, but you can try push starting it. Is it manual or auto?
Have someone tap the starter solenoid with a hammer while you crank it, if it starts then, get a new starter.
If that doesnt work, jump your clutch switch and see if it starts then (top of clutch pedal)
its an auto but i dont think that it is a ground otherwise all electrical components wounldnt work properly. its not a slow start it just clicks once when i turn the key and thats about it doesnt even start to crank, all i can think is possibly main relay but that woundnt cause the starter to slow down so i think it may be the starter more than anything, thanx for your replys guys if anyone has anyother ideas let me know.
It's your starter. My 91 accord was doing the same thing and would even start sometimes when it wanted to with no problems. Other times it would have a hard time starting, and other times I turn the key, and nothing....not even a click. I took the starter out (Easy to take out; only has two bolts on top and bottom and another one that connects to the positive terminal) took it to autozone and had it tested three times and it finally failed on the third go (shaft wouldn't extend) Autozone has a remanufactured one w/ lifetime warranty (Mitsuba) for like $79.99 with a $30.00 core charge.
Wow first post and got the answer right. This guy deserves a medal.Oil leak?What oil leak? That's just sweat from all that horsepower!
Applied knowledge is power!
NITROUS FOR YOUR BODY
BIRTHDAYS ARE JUST AROUND THE CORNER
registration is free
Originally posted by koolkoreankedWow first post and got the answer right. This guy deserves a medal.The beginning of a new era............................
starter. you had me at "it clicks once" so sounds like your pinion gear isn't spinning once it has been properly pushed out when the solenoid tells it to... its done.
and your right, its not your main relay - your main relay has nothing to do with your starter, so good job on that deduction
you can easily find more info about your starter and people with the same problem by searching here, or by going to your local pep boys and picking up a haynes manual
or start here: http://cb7tuner.com/vbb/showthread.p...tarter+problem and look through the first few posts, like the one about banging on it to see if it helps (aero, you mention that in this thread, too)... or checking your ground wire.
if you go through all this and change out your part and STILL have some bizarre issue, please feel free to come back and tell usLast edited by i'm the girl; 12-30-2005, 07:03 PM.
breathing is deadly underwater...
