wat do i need to remove in order to get the damn heatshield out..i try to unplug da O2 sensor but it wont budge. wat tool should use to remove it???
i cant remove my heat shield..
Originally posted by zipcreatureDear Accordlx,
There are only a few bolts holding the heat shield in place. Remove them, and you should be able to wiggle it past the o2 sensor.
- Zipcreature
MY 1n2 CB7
Just grab a hammer and bang away... You dont need no dang o2 senser.Oil leak?What oil leak? That's just sweat from all that horsepower!
Applied knowledge is power!
NITROUS FOR YOUR BODY
BIRTHDAYS ARE JUST AROUND THE CORNER
registration is free
Unless you're swapping headers, it's better to leave it on. It'll decrease under hood temps, and hold heat into your exhaust so it'll flow betterOriginally posted by DoctorCipher...the beginner forum was created to provide a place for all the stupid ass questions to pile up and fester, kind of like huge globs of mayonnaise left in the sun for weeks at a time.
Originally posted by Accordlxyeah i remove those 3 bolt and wiggle around fo like long enuf but still doesnt pass throuh the o2 plug.....my car is a 93 lx
They sell a special socket for the o2 Sesor.
I got mine from Snap-On. ITs quite expensive...
After you remove that, then u get the 3 bolts. (Use Rust penetrator)
Unless you are swapping Exhaust mani's you shouldnt take off the heat shield.
Removing it would increase under hood temp.
Thus increase Short ram intake temp., which in turns equals less HP.
Plus...the LX header looks madd ugly...
