automatic transmission - holding gears
    is your tranny throwing any codes?
      what do you mean
        first gear should shift at 2800rpms at light throttle. so u good.
          Originally posted by rickyduckworth
          you need to find a good mechanic.......you are useless
          i have an idea..........you're that bmx guy, aren't you? ride your bike
          just keep that chain lubed
          or better yet, no, just ride the bike
          whats your problem??
            When you start getting impatient and start sounding rude by the verbage you type the responses get hostile. I am on this forum several times a day just like alot of other people. But we don't live here so give the others some time. If you don't have time so wait you will have to pay a mechanic. And even the mechanic is going to hold you up for most of a day.
            It really is a labor of love making a neglected CB7 with "normal wear and tear" into something worth being proud of.
              how did i get impatient? i accidently typed well twice....big deal
                it should shift in second geart around 2700 or 2800 rpms at normal throttle so u good to go man.
                  thanks, good to know
                    its all in the tranny cable. adjusting that tranny cable its a bitch.
                      um have you checked your coolant temp gauge to make sure the thermostat isn't bad?? If it's okay, have you checked the other temperature sensor that goes to the ECU and TCU?? If it's bad and sending "cold" to the computers, the Transmission will intentionally shift late a lot like what you're describing.
                        The oil on the plugs shouldn't have anything to do with the way its shifting, nonetheless get that fixed anyway.
                          i would check this stuff... but i have no idea where it is. ive looked around and i dont really know what to check, but im trying. and now i hav a stupid coolant leak and i gota look for it tomorrow.
