Hey whats up guys...
Okay, i picked up a 90 Lx Accord last week...did some few things to it...radiator replaced, battery, valve cover gasket replaced along with spark plug O-rings...
I am having trouble fixing the rear brake light...the bulb works fine...i changed them twice. When you press on the brake, that bulb is supposed to light up...does not light up at all.
I dissassembled the housing, checked the grounds, everything seems okay...
(i doubt it's the fuse, because the other, right brake light works fine)
I also sanded down the crust inside the contact points...
This is mind boggling...
any tips?
(Im new here, please keep the flaming down
thanks in advance!
any tips?
thanks in advance!
