the car starts do do a poping at 5k rpm from the exhaust and the car doesnt go anywhere it loses power
can wont go past 5k rpm
hmm yes that sounds right too, cause if the timing is off thats what causes theproblem andthe timing set wrong or the distributor goin out and making the timing off, would all cause this..so have it checked out92 CB7 *Sold $3300 102K Miles 4 door LX
94 Del Sol *Baught $3300 80K Miles on chasis
and 60K miles on b18b1 motor swap
Its not the ignitor, its the dizzy assembly itself.
I had the same problem on my sedan, I just never revved up that high, until I had to pass people. I replaced fuel pump/filter, cap/rotor, wires, spark plugs, ignitor, and figured it was the cat being clogged since it kinda sounded like a backfiring sound. Replaced the whole distributor assy. and solved it.
