Ok i have been posting heavily on HAN, and i figured i would come here cause you guys know my car better. Anyways i rebuilt the whole engine, top to bottom the head was completly rebuilt.. ect. ect.
i started reassembling the engine replaced practicly everything in the engine bay (winter time). So i get it all back together and start the engine.
The engine ran fine it purred and i let it run for about 30mins at idle. perfect idle everything, so i rev it to about 2.5k it coasts smoothly and i have a giant grin on my face.
I take it for a test drive and all is good. After like 10 mins of driving i decide to give it a little but more gas (i never went over 2.5k) so i hit and in 2nd and the tires kinda chirp and it takes off (i was supprised, that engine builder did good) at 4.5k i shift and its all good.
so on my way home from the test drive, out of no where, the tach spikes like crazy (going all over from 2-8k) then all my gauges die i hear a clicking and the car stalls no matter how much gas i tried to give it.
i had to call a tow cause it wouldn't start and the next day it started right up but if i reved to 3k it would die and stall the same as before.
now the engine will not start at all, i took the belts off it was slightly out of time (tensioner sliped i belive) so i retimed it and it wouldn't start (it still backfires really bad while tring to start).
there is suction in the exhaust. so i moved all my plug wires over 90 degrees and pushed the distributer way back and the car would start but then die, and that is the only way i can get it to start.
I Have no IDEA what is wrong with this car, and the cam timing seems to be off, i put the engine in TDC, with the marks on flywheel and crank, the cam is in "up position" and lined up with block. and the distributer is 90 degrees outta time, it should point at #1, but its pointing at #3... is there any why thats possible the cam is one solid piece???
I am sorry for the novel (i have tried searching) if you read this i commend you on that alone, if anyone can help that would be greatly appreciated
