still stranded electrical problem???
    ok my car died the other night at a light after being drivin for like 20 min or so... and well now it wont start... along with that here are the other thing not working..
    wipers
    CLOCK (at second key turn)
    windows(at second key turn)
    and what does work still..
    headlights
    dash lights
    stereo.
    alarm
    please i need my car back ASAP
    from f22 to H22. still love the cb7.
    bump please help me out... n e input please
      Did you check all the fuses and also check the factory relays. -damien
        check your main relay high under dash ,left of colmn . that is the relay that goes out most common
          Try Ignition Switch
            Originally posted by DAVIDJENNIFER
            Try Ignition Switch
            im swinging in that area...
            now u cant start your car right.....turn the key very very little, and i bet your clock and stuff will come on. if not then there may be a dead spot in the ignition switch.
            i had that issue...everything would fade and then turn off...the only way the car turned on was if the key was almost in the "start" posistion and if i held it there.
            if fuses and stuff is ok, look into it...its like 45 bucks or so, about 30 minutes to replace with beer.
            Retro!
            Hater
              thanks for the replys everyone... fast as usual.... the realays were fine... im deffinetlly gunna look into the ignition switch.. just would that stop all the other stuff from workin too...
                what were you doing to the car under the hood to before it began the sympoms? One thing that people usually forget to mention when it comes to problems like this is...
                In the engine bay right behind the headlights there are these 2 little boxes that are bolted to the side of the bay. they are about an inch and a half square and half inch thick. theres a bunch of wires that go into the box. these are main grounds for the majority of systems in the car and if they are removed some things will work some wont much like the issue you are having. i would unbolt both and clean up the grounds and bolt them back down.
                I learn the hard way when i was cleaning up the wiring in my engine bay what unbolting these things does.
                member ride thread
                DIVULGE MOTORSPORTS
                  If the car dies while driving there is a good chance that it is your alternator, i went through two batteries like an idiot before i figured that out. >.<, so get that checked out, and dont do the shitty load test they offer at autozone or where ever you go. Take the alternator out itself and take it in [if thats what you believe that problem is] thats my 2 cents.
                  "you know what a neo-conservative is...it's someone who watches the matrix and believes it's real" - lewis black.
                  ohio cb7's #9
                    thanks n e ways guys... but i couldne figure it out soo i got it towed to a local honda acura fix shop.. should pick it up tomorrow
