Maintenance Required Indicator
    I need to find out how to reset the maintenance required indicator back to green.
    I'd appreciate some words of wisdom
    Thanks
    Just Purchased My First CB7!!!
    There is a small opening in the cluster bezel near the indicator for resetting. Use your key to push this in and it will reset back to green. I believe the owners manual (if you have one at hand) also advises to do this.
    '92 Accord LX Sedan--Bordeaux Red Pearl --OEM--279k Daily Driver
    EX Lip & Alpine OEM single CD Player. No more useless pocket!
      "push da budon, push the godamn budon!!" *in the voice of the kidnapped lil girl in Rush Hour.*
      -Jose
        yea it turns every 7500 or so i think
          ugh.. this thread again?..
            Wee...another wasted post. Wooo...let's waste space.
            I'm wasting space like you...I'm COOOOOOOOOL.
            I suppose you could always get a cluster without the indicator if you wanted as well. Or just put a piece of electrical tape over it.
              ^^^ wow thats so useless both of you, and you really should make your sig smallerr..
              anyways, as said above, stick your key in the slot. thats about it
              even if you dont nothing will happen, its just a color. and IMO you should be changing your oil and checking the engine more often than the light tells you too
