anybody experience this...? its like a wining noise coming from the steering wheel when making turns. also steering feels loose like when i make a turn it wobbles sorta like if u have a semi flat tire and u turn the wheel.
Noise from steering colum area
yes check your belt for the power stearing, (might need to be tightend and also check fluid when it is cold on the pstearing and u might need a pump ive been through this 2 times with my car and also check the low and hgh pressure hose
and also forgot to add if u are low on fluid check out why u are low might be a leak dont just fill it and let it go cause im might cause more damage then u thinkLast edited by hpaccord91; 11-29-2005, 04:55 PM.
(\__/)
(O.o )
(> < ) This is Bunny. Copy Bunny into your signature to help him on his way to world domination!
