NOOB with a question
    Hello CB7 Tuners, Im KC from Tucson. I just joined the forums (referred by someone from Collective Racing). Anywa I had a question about my new to me 90 Accord. I was driving home last night and my car stalls. It didnt want to start back up again either. I was noticing on the way back from Phoenix that the car was kinda surging and threatening to stall at times (as in power would cut out momentarily). The car is also having a hard time starting up in the cold. I also dont have a speedo most of the time. Other than that the car is running strong. I had the alternator checked and it is charging the battery just fine. I appreciate any help on the subject and am looking forward to getting over this and starting some engine work.
    Sounds like a prob with your distributor. Check your coil and igniter. Follow this link for troublshooting problems with distributor components:
    http://techauto.tripod.com/s.htm
      Thank you. I appreciate it ! Ill keep you all posted.
        hey, man... I was having the exact same problem... and it wound up being my ground going to my motor... was completely gone.
