Hey all I need help to reset my ECU I read some where you can do it with paper clips but I'm not to sure about it so I need some people to help me out. Thanks
Resetting the ECU?
Resetting the ECU?
Henry R
Koni/Neuspeed
1992 Accord LX R.I.P
1993 Accord EX OG since 'o3
Legend FSM
made by someone who wants something' -1943 US War Department videoTags: None
no matter wut, ur stereo will be resetted..so if u dont have a code for ur stock deck watch out.
no way around thsi reallyWhat makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Originally posted by BustedLX
To reset your ECU you remove the fuse label "Back-up" in the under hood fuse compartment for 10 seconds. Or what most people do is just disconnect the battery negative for a few minutes.Henry R
Koni/Neuspeed
Legend FSM
remove the back up then.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Originally posted by Accrdkid
I tried to remove the negative cable but I need the light shut off its getting annoying and its been on for two years since my f22 swap from an ex
