Resetting the ECU?
    Resetting the ECU?
    Hey all I need help to reset my ECU I read some where you can do it with paper clips but I'm not to sure about it so I need some people to help me out. Thanks
    Henry R
    Koni/Neuspeed
    1992 Accord LX R.I.P
    1993 Accord EX OG since 'o3
    Legend FSM
    To reset your ECU you remove the fuse label "Back-up" in the under hood fuse compartment for 10 seconds. Or what most people do is just disconnect the battery negative for a few minutes.
      no matter wut, ur stereo will be resetted..so if u dont have a code for ur stock deck watch out.
      no way around thsi really
      Retro!
      Hater
        I tried to remove the negative cable but I need the light shut off its getting annoying and its been on for two years since my f22 swap from an ex
        Henry R
        Koni/Neuspeed
        Legend FSM
          remove the back up then.
          Retro!
          Hater
            the check engine light stays on?.. if so.. uh, theres a reason for it.. the ecu is detecting something wrong with your car.. find out what code its throwing and fix it..
