oil pressure gauge?
    oil pressure gauge?
    What wire do i hook the oil pressure gauge to on the ecu?
    oil pressure on ecu? no such thing.
    you have to have a adapter of some sort to hook up to the stock oil pressure unit and it is electronically sent from there. it should come with the guages.
    then you run a power wire from any source and a ground.
    search for guage, or oil pressure or oil* pressure and there is a thread all about it. if u cant find it let me know.
    Retro!
    Hater
      yeah really.
      i installed one a month ago. u have to run it to the oil sensor with a adaptor and a tee fitting. then run the tube to the back of the gauge. its easy/hard.
      easy to screw in tee fittings and stuff but i think the hard part was running the tubing, u ave to make sure it doesnt bend, its plastic
      NEED RAP BEATS.....
      www.soundclick.com/akcidentaltrakz
        it looks like a baby sensor like a small bolt I have the same thing for my water temperature after hearing they have to drill in the head i was like oh hell no and took it out now its only there for display.
          ok thank i think i might have it
