So I just recently did a swap/conversion on this auto 96 EX. Now has a JDM F22A, 5spd. Used the boomslang fabrication OBD2a -> OBD1 conversion harness. Using PT3 ECU.
As you know, the CEL stays on while the pump primes for about 3 seconds... then it's supposed to turn off when the pump ceases priming. Without even trying to start (which of course it won't) my CEL stays on...when pulling codes, I get #16 (injector/circuit).
Here's what I've tested so far:
Main relay is good.
All fuses are good.
All resistors in resistor box are within spec.
Resistance of injectors are within spec.
There is continuity between yel/blk wire at main relay and yel/blk at resistor box plug.
There is continuity between red/blk wires at resistor box plug and their matching wires at the injector plugs.
There is continuity between individual injector wires and their respective pins at the ECU (A1/brn, A2/yel, A3/red, A5/blu).
Yel/blk wire at resistor box plug is hot when ign. switch is set to ON.
ECU pins A25 and B1 are also hot when ign. sw. is ON.
I really don't know what else to test, I went through the entire injector circuit... is there something else that would trip a code 16? First time in a long time I've had a real WTF like this...
EDIT: I can also read resistance of individual injectors by using ECU pins A1, 2, 3, and 5, and the red/blk wires for the resistor box plug. It's all there. What the fuck am I missing...
Main relay is good.
All fuses are good.
