My JDM F22B Intake has no ports to clean out the carbon. So how does one go about cleaning it? Anybody else dealing with this issue?
? How to clean F22b Intake ports?
i'm assuming you mean the EGR ports where it recirculates the exhaust.... with those, the only way you can clean it is by drilling out the plug inserts over the port on each runner and tapping them for a threaded insert, or you can do something like this DIY and just pull out and replace the normal plugs... http://home.comcast.net/~em-engineering/T2T013.pdf
^^^yes u do have a egr, but still not sure wat u r trying to do?=my idea of classic JDM
to my car page
Originally posted by ChroNicBoosTi'm assuming you mean the EGR ports where it recirculates the exhaust.... with those, the only way you can clean it is by drilling out the plug inserts over the port on each runner and tapping them for a threaded insert, or you can do something like this DIY and just pull out and replace the normal plugs... http://home.comcast.net/~em-engineering/T2T013.pdf
yea no doubt man... good luck w/ it.... i just did it on an A1 mani i have that'll be goin on my car when my arp headstuds come in... i actually sealed up the holes with bolts permanently and i actually cut open the egr valve and welded the entire thing shut to completely cut off the recirculation... my ports were PACKED with carbon build up and it was disgusting... not sure what the best agent wold be to clean all that crap out, possibly a degreaser... all i did was hit the ports with air and blow the heavy crap out...lol...
