Hey im new to the forum posting wise but ive been checking it out for 5 months now, anyways, my 90 4 dr auto EX has some quirks in it, First there is an oil leak right under the oil pan and transmission area everytime i park, i guess its a oil pan gasket and i have all the stuff to fix that but i just wanna make sure taht this is the problem cause im also getting an H22 soon. Another problem is that I get hard vibrations when in park, I think it maybe the rear engine mount but im not sure, it only happens when the car idles under 700 rpm and in any gear. Lastly sometimes when i put my car into reverse i hear a loud pop rigth when it switches to reverse, maybe its the transmission or it could be a ball joint or something in the wheel area, not sure well anyways just want some A to these Q's
Minor Problems
Originally posted by JaiBeezy DnB...First there is an oil leak right under the oil pan and transmission area everytime i park, i guess its a oil pan gasket and i have all the stuff to fix that but i just wanna make sure taht this is the problem cause im also getting an H22 soon...
It could also be a stripped Drain Plug bolt.
If it is, just get a new Oil Pan, dont try to Re-thread it.
Reason i say that is because it is a nice chance to upgrade to someting new.
But make sure that it is Engine oil and not Tranny Fluid.
Originally posted by JaiBeezy DnB...Another problem is that I get hard vibrations when in park, I think it maybe the rear engine mount but im not sure, it only happens when the car idles under 700 rpm and in any gear...
Thats one of the first thing to go.
The Rear Engine mount is vacuum controlled, so if you can check to see.
Originally posted by JaiBeezy DnB...Lastly sometimes when i put my car into reverse i hear a loud pop rigth when it switches to reverse, maybe its the transmission or it could be a ball joint or something in the wheel area, not sure well anyways just want some A to these Q's
Bad Engine mount can have an affect on the Tranny.
Replace that, and you're going to see a noticeable effect on Performance.
