I have a 93 JDM H22 and my oil pan gasket needs to be replace, can i use the USDM gasket ones that Honda dealer sells? Does it need to be in a specific year?
JDM H22, USDM H22 OIL PAN GASKET DIFFERENCE? Same?
I'm not 100% positive, but close, I'm pretty sure they're the same oil pan, so the gasket would be the same too. I know afew people on here have rec'd their JDM H22's w/ dented oil pans, so they put on their old F22 one. Also one guy on HPOA.org put on the aluminum H22a4 pan onto his JDM H22. So, it should be the same.
If you have the time, take the pan off, bring gasket to auto parts store or Honda and compare them.
Good luck and I hope that helped
Dan
EDIT: F22ax, H23a1, and USDM H22a1 oil pans are exactly the same, so are the gaskets, I believe.
