i was just sittin in my car with the engine on in neutral, and just bein bored i flashed my brightes at the garage, the rpms droped about from 1100, to 1000, is that normal?
is this normal
I wouldn't freak out too much... when you reduce the resistance of a circuit therefore causing greater load on the output side of some kind of mechanical generation device, like turning on your high-beams (such as an alternator) the physical input side is going to be harder to turn (and causing your rpms to drop). If your battery and alternator are in good shape and this still happens, it's normal.
EDIT: I just realized my first sentence structure fuckin' sucks, but whatever. If you have a brain you can read it.Last edited by Dirty Harry; 10-31-2005, 02:43 PM.
