what would this be
    what would this be
    sometimes my accord wont start but then if u let it sit for like 30 min then come out it will start right up do u know what it would be
    search the forum. does it do it when its hot, cold or what. sounds like a main relay to me. usually these go in the cb7 and most of the time its during hot summer day. the solder inside becomes lose and eventually falls apart. itll get worse and worse until it gos. search "main relay". good luck. try to be more specific.
      it does it when the engine is cold and it just sounds like tho motor is just trying to turn over
        sounds like the main relay... we were talking about the outside air when he asked what temperature...
          do a full tune up. plugs,wires,cap,rotor,fluids,check alternator and battery(auto zone tests both free) and go from there.calsi make sure all of your ground wires are clean. if they have the green crap all over them clean them up a bit with a wire wheel and drill or some sandpaper. good luck.
            later.
            Avoiding dirt at all costs
