Are there any symptoms of a timing belt going bad?
    Or is a visual inspection all I can do?
    What could happen if the belt is stretched?
    Anything at all from your past experience?
    My CB7
    wining noise
      The belt do not stretch they just burst. You can check the teeth on them and make sure they are not frayed or look worn.
        Thanks guys, anyone else?
        My CB7
          Originally posted by 93accordexcoupe
          wining noise
          Does the belt wine or is it a bad water pump that does the wining?
            probly both, i really have no clue, their both bad on my car
              lol thats no good.
                Make sure you do not exceed the 90K mile interval too much because there no warning before failing.
                  weak timing belt
                  listen and feel your cb7 upon start up before my F22a4 snapped its belt upon the second to last time she ran the was a weird vibration that I had never felt before, upon the last time it did it again, 15 secs later while shifting to 2nd gear at 25mph she stall in the middle of an intersection in the rain. Take it for me monitor your mileage and do routine maint., and even though they are none interference engines still bent valves cause of the tq. Just my two cents.
                  Mr. $3 Dollahz Himself!
                    This is actually for my Civic...
                    I'll check the belt on Wednesday when I put my headers on (hopefully they come by then)
                    My CB7
                      Im sorry, but you are wrong. They ARE interferance engines.
                      Seattle Silver crew #5
                      Member of the Midwest Car Club.
                      ..........2004 accord ex v6 - J30A4.......................... 91 accord ex - JDM H22A -- Long gone...
                        Nope, there is no warning, no noises, and no good way to inspect it. It isn't like a regular drive belt that you can look for cracks on. A timing belt looks normal, up until the time it snaps. This is the reason why you must replace it based on time and milage...not visual inspections. Every 90K or 6 years.
                        00 Jeep Grand Cherokee 4.7 V8 4X4
                        92 Honda Accord LX
                        95 Honda Civic CX
                          Yup. That's exactly what I've heard from a number of people.
                          If the belt brakes, you're out a motor. I'd just do the timing belt if you don't know and have reason to suspect it's comming up.
                          2DAO (2 Door Accord Owner)
                          JDM H22 DOHC 200/161 2.2L
                          My members ride: http://www.cb7tuner.com/vbb/showthread.php?t=20385
                            Yeah, I guess its a good idea to change it...
                            My CB7
                              mrhonda got it dead on.. and actually, youre not necessarily out of a motor if it snaps.. depending on what rpm it snaps at, the damage could be minimal..
