OK so my 92 ex has always pullled to the right. I bought it from the honda dealership and i told them that it pulled to the right so they gave me new tires. But it still went right. Then I got a front wheel alignment and it still drifted. Then I went back to the dealership two years later and got an all wheel alignment which they are suposed to take it out on a test drive and see if its fiine. But I immedietly could tell that it was the same. I went back and they said they could do nothing. Basterd dealership. Whats up with my car? Is it my suspention? struts? My brakes are fine.
Pulls to the right no matter what!
Suspension problem.
I had the same problem, no matter how many times i Aligned it
or wheel balanced it, it still pulled.
Come to find out it my was my tie rod ends.
So if you have access to look under your car i suggest you do that.
If not, take it back to Honda and tell them to put it on a lift
and really check out what is going on under there...
