Whine In car only when in gear
    Ok,
    So my car whines will it's in gear. It's a 5spd JDM H22a setup and I was curious as to what could be the culprit? When I put the clutch in, the noise goes away all together.
    It really happens in 1st when I'm accelerating from 1k-3k RPM, not so much on decel. Can't hear it as bad in second gear...
    Any ideas?
    I'll post more details when I get back,
    Thanks
    2DAO (2 Door Accord Owner)
    JDM H22 DOHC 200/161 2.2L
    My members ride: http://www.cb7tuner.com/vbb/showthread.php?t=20385
    Does the clutch feel funny at all? and is it hard to shift at certain times? how does the car sound when its in neutral? jsut trying to diagnose what your trying to tell us
      Check The Fluid Level!!!
        yeah... do that!... i just rebuilt my cb7 tranny with new syncros and an lsd and stuff.. and for some reason mine does the same thing in 3rd... good luck
          No. No. Fine (Normal).
          Lol. It's weird I know.
          I'll check the fluid levels and get back with you guys...btw, on that note, there is no other way to do it other than to pull that top plug on the bell housing off is there? (The one where you put the fluid in...)
          Thanks
            *bump*
              Thanks
              i dont think so.. and damn.. its a bitch haha.. good luck dude.. and let me know if you find out anything, cause i would like to know... cause of 3rd gear...
