The car:
92 accord ex
JDM H22
The problem:
When I attempt to start the car, I end up having to crank it for a good 20 seconds before it will start. One thing I have noticed is that the fuel pump doesn't pressurize the system when the key is turned to accessory. I believe it is supposed to do this. I took it to my dealer in january and the mention something about the fuel pump having 2 grounds, but one was missing. I've looked and haven't found any trace of where this second ground could be or have been.
Parts replaced:
Main Relay
Fuel Pump
Fuel Tank [not related, but I did it]
The Question:
What else can I do to fix this?
What am I missing?
Where should I look next?
Does anyone have any experience with crap like this?
Of Note:
This started right after my swap was installed. I didn't do the swap, and I've been wishing I had ever since. But, what did those monkeys do that caused this.
Is there a pin in the ecu that is the ground for the pump?
Cliffs:
Got my swap, hard to start, replaced a bunch of stuff, still doesn't start right, me = mad.
Thanks guys.
92 accord ex
JDM H22
The problem:
Parts replaced:
Main Relay
Fuel Pump
The Question:
What am I missing?
Of Note:
Cliffs:
Thanks guys.
