Brake/Horn Fuse keeps blowing!
    Hi guys,
    The other day my horn stopped working....upon inspection, i found that the fuse is blown.....replaced it, and right away it blew again.
    I'm hoping you guys can suggest a good method to tracking down the problem....
    Thanks
    Try removing things on the circuit that might have a short. Starting with the horn. This assumes of course that your wiring is in good shape ...
      wiring seems to be in good condition. I will investigate when the rain stops.
        i had the same issue once, turned out i had smached the horn's wires between the bumper support and frame.
        Seattle Silver crew #5
        Member of the Midwest Car Club.
        ..........2004 accord ex v6 - J30A4.......................... 91 accord ex - JDM H22A -- Long gone...
