my intake manifold has smoke aorund it idk where its from and cant really describe the smell the car runs fine and is staying cool can someone help me out. its a white kinds steam and it kinda smells sweet but the antifreeze level hasnt dropped also this morning it was letting some white smoke out the exhuast can some one help me out
help me smoke from intake mani
95% its a blown headgasket
ILBBPeople I have dealt with in this board- Smseagren83,d112crzy, Idrivealude, aznpnoyracer, wed3k, dinertime, HF22T, MRX, Dc2lewd, yeamans17, bruno8747, tn_accords, king james, starchland, yardiexd40
Mk3 Supra Member #2
Originally posted by DarkShadow707The world needs to be reset.
do you plan on diy?if you do,word of advice:lock the flywheel.Good luck
Mk3 Supra Member #2
id look at the problem a bit more closely first.
first id try to clean up the rear area of the manifold to see if you can find where its comming out. let it run and see if u see fluid around a certain point.
sometimes you will find that a small drop falls somewhere else (coolant) and burns but its hard to find that.
you can also do a pressure test on the radiator, if there is a leak you will see the pressure drop and the leak as well.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
