when doing a f22b1 sohc v-tec head swap can i use the distributor from my f22a4 or do i have to use a v-tec distributor? the f22a4 will work but i heard that you must use a v-tec distributor with a v-tec motor. any help will work i just need to know if i can and if so will i still be able to engage in v-tec?
which distributor?
Originally posted by Kabuki
Now Busted, they ARE different units and use different caps and rotors, but either one will work. Just use the one you have. That's what I'm doing.
