I have just bought a 91 Accord DX and it is leaking oil for it looks like around or right above the oil filter. The guy I bought it from said it started about a month after he changed the oil and I tried to tighten the oil filter but it is tight. Could it be the oil sending unit of maybe a gasket somewhere close to the filter? Let me know. Thanks
Oil Leaking BAD
If it's leaking around the filter, remove it. Check for an old gasket there, or stripped threads. If it's coming from that general area (around the filter, above, below, etc) it's more than most likely the sending unit. Easy seven dollar fix, or less. It's right above the filter, which you'll have to remove to get at the sending unit. Remember, once you remove the filter put a new one back on, to ensure a good seal.Coming soon....
