Well i went to meineke this morning same meineke ive had install several performance exhausts on other cars. This time though the owner was there along with the guy i usually work with. He says its gonna be $300 to install my new cat, muffler and 2.25" piping. I say no way cause i had the same thing done on my last car there and they only charged me half that. Now i dont know what to do cause im certainly not going back there again. Where do you guys get honest exhaust work done?
Exhaust install Headaches
Did you even gasket your car in the first place Wayne?
The best place I'd think for exhaust work would be a local independent shop. Places such as Midas and Meineke will charge way more, especially if they think they'll get away with it.
Just grab the phone book and see all the shops listed under muffler and exhaust and go from there. Any reputable shop should be able to give you a run down of the costs associated with a custom exhaust.
Originally posted by AccordWarriorDid you even gasket your car in the first place Wayne?
i'm assuming you are talking about an exhaust that has to be welded on and made. it is not a "bolt-on" affair correct? if it was then i say you should do it yourself.
i usually see about $160 for everything but a cat and a resonator. $160 includes piping and a muffler (flowmaster) installed after the stock cat. $300 is rape!
