Wierd Sound coming from engine at idle
    my.spacebar.aint.workin.so.bear.with.me
    a.few.days.ago.i.starting.hearing.this.loud.knocki ng-like.noise.coming.from.under.the.hood.....when.im. under.the.hood.its.not.that.loud,.but.in.the.cabin .its.pretty.loud....
    this.ONLY.happens.after.the.engine.is.warm,and.the .tranny.is.in.park.at.idle.around.800rpm.....if.i. rev.it.up,in.park,sound.goes.away....if.i.put.it.i n.gear,sound.goes.away...it.only.happens,when.the. tranny/is.in.park.and.engine.is.idling.at.around.800rpms
    it.is.like.a.fast.tapping.or.knocking-like.noise...sort.of.like.something.is.in.the.way. of.the.belts.and.the.belts.are.hitting.it...
    under.the.hood.it.sounds.as.if.it.is.coming.from.t he.valve.cover.area....possibly.inside.the.engine. ....
    what.can.it.be???
    i.have.enuff.oil...engine.runs.fine.......changed. oil.around.200miles.ago...
    no.known.or.significant.leaks
    also.i.get.sort.of.a.whine.from.the.belts.after.i. rev.the.engine.and.while.the.rpms.drop.back.down,t here.is.a.whine....SOMETIMES,i.get.it.at.idle.too
    what.can.that.be???
    BTW,i.got.a.90EX.with.a.autozone.short.ram.intake
    When was the last time your valves were adjusted?
      Sounds like the valves to me. Sometimes if they are way out of adjustment, or resonate/echo in the head just right, they can even sound a bit like piston slap/ rod knock. I would say you need a valve adjustment. If you drive really hard, every 15,000 miles is pushing it.
        i.dunno.wen.was.the.last.time.it.was.done....i.jus t.bought.it.off.a.auction.about.5months.ago
        but.i.recently.did.a.COMPLETE.tuneup....is.valve.a djustment.included??
        how.much.do.these.cost??.....how.much.damage.can.h appen.if.it.stays.along.time.w/o.one??
        btw.i.got.199600miles
          A valve adjustment shouldn't cost much more then $60 at a local honda dealer.
