Timing Belt Broke Awwwwwwww!!!!!
    my timing belt broke an we did a leak down test an it was good, it broke at 3-3.5 rpms. what else could it have done????///
    1990 Accord EX
    JDM 94 H22A
    busted some valves.....
      at 3k rpm they would be mildly bent probably, not busted.. thats probably the only thing you need to worry about is bent valves..
        ok good because the shop said i had no bents vavles, THANKS GUYS
        1990 Accord EX
        JDM 94 H22A
          WHAT!!!!!!!!!! you didn't learn from my thread??????????? THATS THE MAIN REASON WHY I HAVE NO CAR... yea shops will tell you your valves are fine just to rape you into getting timing belt done along with waterpump, gaskets, balance shaft belt.. then when they go to start it up.. car won't start or its roughs and feels like its running on 3 cylidners.. man you gotta learn.. EVERYONE SHOULD LEARN FROM MY MISTAKE.. NEXT CB7 OR CD5 I'M GETTING I'M CHANGING EVERYTHING out from undercoating to the headliner... lol
          http://www.get-gifts-for-free.com/?ref_id=4810
          1992 Honda Accord 4dr 5spd EX- R.I.P 8/10/05
            mine runs fine vtec just doesnt engage how it should
            1990 Accord EX
            JDM 94 H22A
              IF they say it wasnt bent check for yourself
                Yeah I agree with sparkle, these engines are interference engines. Rip off the head and confirm it for sure.
                  i was there when they checked
                  1990 Accord EX
                  JDM 94 H22A
                    I doubt they pulled off the head, checked the valves, and replaced the belt in one day. A simple leakdown test, eh?
                      i'm pretty sure that you can slap a t belt on and it will be o.k. i replaced a t belt on a h22 before withe the same deal. also an integra and it was o.k.
                        You know what, if you people would just replace these godamn things when you're supposed to you wouldn't have these problems. So....whats the verdict, are the valves bent or not?
                        00 Jeep Grand Cherokee 4.7 V8 4X4
                        92 Honda Accord LX
                        95 Honda Civic CX
