the problem came back stereo?
    wtf it came back i yet have tryed everything i dont know what the hell to do new grounds sorting out wires getting crossovers from the amp it was great for a while and then it started back up maybe its the amp i am wondering i have the amps screwd to the back of my seat maybe if i make a bored and put the amps on it and screw it down it will be better not sure but its the amp for the speakers when i disconnect the amp its great but only the front speakers work when i do that but the amp to the sub is fine doesnt do it im wondering if its the old amp maybe i went back to tweeter and they said everything was great and it should make any noise the stereo is grounded fine all rcas are fine stereo works great when i disconnect the amp component system
    ANY IDEAS NEED NEW AMP I HAVE ONE IM GONA TRY TOMMOROWSEE WHAT IT DOES ANY SUGESTIONS
    (\__/)
    (O.o )
    (> < ) This is Bunny. Copy Bunny into your signature to help him on his way to world domination!
    how many channel is the amp going to the speakers? is it 4 or 2....are u sure there is nothing comming out of the speakers?
    u can put a 9 v battery to the positive and negitive of the speaker leads to see if the speaker line to the speaker is good...u will see the speaker pop (dont do that too many times).
    if it is a 4 channel amp, how many rca's u got going to it? 2 or 4? if there is only 2 then thats ur issue......u can also put the rca's in another input on that same amp to test the other channel...if that channel works when u jump the rca's then the rca was bad to begin wiht.
    basically u want to test the system part by part....seeing if the speaker leads are actually connected to the speaker and if the speaker is working, test to see if the rca's are working etc.
    i cant really understand your post, at least use a period
    Retro!
    Hater
      im with him all i got out of that was it has something to do with an amp.
      Originally posted by Dr.x
      You drive an almost 20 year old car, pretty much everyone can pay it off.. you dont need to be "ballin"
        lmao
        http://www.get-gifts-for-free.com/?ref_id=4810
        1992 Honda Accord 4dr 5spd EX- R.I.P 8/10/05
          well i thought it was under this catagory if u look under audio i have a post under there i put it under the wrong spot and thankls man i have a bad channel i switched channels on the rca and it doesnt make that anoying humming noise anymore thanks
          (\__/)
          (O.o )
