post your MPG's and what you do to improve it... Everybody knows the obvious things like driving slower, not using A/C, drive a stick-shift, blah blah... but this should focus on things we can do specifically to our cars...
I get about 26 MPG mixed city/hwy. I can go about 350-380 miles on a full tank with 87 octane.
Here's a list of what i've done recently and i have noticed a big difference.
*replace spark plugs
*replace air filter
*replace cap and rotor
*replace fuel filter
*replace thermostat (was running too cold)
*use D3 in the city
*only use 5w30 oil
*replace gas cap
*replace oxygen sensor
*keep tires at 32 psi minimum
*replace spark plug wires
*use michelin "energy" tires
*clean EGR ports
*check ignition timing
that's all i can think of
*replace air filter
*use D3 in the city
*only use 5w30 oil
*replace gas cap
*clean EGR ports
