The title is pretty damn descriptive if you ask me!
My DX is having a problem... the climate control is on permanent heat (which is a little uncomfortable in August!). I messed with the climate control unit while trying to change my dash bezel (found not all of them are the same... didn't fit... that's another story though). Apparently everything was, and is, hooked up properly there. I've never removed a dash before, so I don't quite know what else it could be. I'm assuming it's something behind the dash that needs fixing/replacing/reattaching or something?
It's the DX style controls, with the 2 sliders (only the fan has a knob). The lines are hooked up ok, but it won't go to cool. The temp slider moves fairly easily, but seems to have a little tension on it...
Any ideas? I really don't want the heat on all the time!
