When i am stopped, my engine seems to rough idle. esp if I am in revese, it will like shake the hell out of the hood. could it be anything with the belts or fuel filter? I got mad parts and paint going on my baby in 2 months. Just want to know what maybe the problem could be. Air filter is a k+n and clean. spark plugs are ngk. thanks in advance
Rough idle.
shaking in reverse can be a broken front motor mount or a very low idle. what is ur idle in park, and in gear?
check ur front mount, look inside, there should be rubber on 3 parts of the metal, if not then its that mount thats messed up.
check the other mounts as wellWhat makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
