Oil in spark plug chamber
    well i got my NGK irdiums finally...and 8.5 mm racing wires... well i found oil in my spark plug chambers...it weird because i just changed out my valve cover seals and spark plug seals on the top...where else is the oil getting into...
    also if i pull my old spark plugs out ...and the oil gets into the combustion chamber will it just burn this excess oil off or should i just try to extract that oil sitting in the spark plug chamber?
    i remember reading somone is using epoxy or honda glue somwhere in the valve cover to stop this but where at... thanks cb7 team.
    Not to be a dick....but I've answered this question a million times already....the search button is your friend.
    00 Jeep Grand Cherokee 4.7 V8 4X4
    92 Honda Accord LX
    95 Honda Civic CX
      Hey Dick...i mean mrhonda could you point me into the right direction.. i mean the search engine on here isnt exactly google buddy
        tube seals
        FA1
        355
          Originally posted by 2.2litrebeater
          tube seals
          thanks mang...ill check advanced auto parts tommorrow
            felpro kit
            upper, lower and valve cover seals. i just picked it up.. and i will attempt to do it.
            hahahahah
