I've already searched forums and threads about this problem but, none of them seem to be about the same problem I'm having. I bought my Accord last December and havn't driven it since. I recently replaced the clutch and am now driving it on a regular basis. I turned the A/C on for the first time ever today. The far right hand vent blew out cold air with vapor while all of the other vents blew out cool air. If all of the vents were blowing air that was only cool, I would assume that I needed to recharge the A/C. Has anybody experienced a problem anything remotely like this? Thanks for the help.
A Different A/C Problem
The same temperature will blow out all vents, + or - a few degrees, but its not going to be a major difference between them. The water vapor was caused by the difference in humidity when the cool dry air from the a/c met the warm humid air in the cabin (think meteorology and how clouds/storms are formed in regards to fronts meeting air masses. Don't get it? Go watch the Weather Channel for a few minutes and report back.).Last edited by ACCORDianate; 07-23-2005, 09:00 AM.Former: 90 Accord EX Coupe, 93 10th Anniversary in Frost White
That's what I figured. But, the vapor is only coming out of one vent, the furtherest most right hand side vent. Cold air blows out of that vent while the others vents only blow air that is slightly cooler than the outside temperature. (Kind of like when the thermostat is broken and all of the vents blow air that's only marginally cooler than the outside air.) Is it possible that there is a blockage or a crimp in a hose somewhere? I don't know much about A/C systems .
