Removing B pillar trim
    I did a search and didn't find anything related to this. I have a 91 sedan and the tops of the pillars are warped on both sides of the car. I pulled out some of the weatherstripping but I cannot find screw heads nor figure out how to remove them. Any help is appreciated!
    Thre are three screws on the left side of teh pillar (looking straight on) YOu remove the weatherstripping and you'll see three phillips scres attaching the pillar.
    Hope that helps, and I have an extra driver side one for a 4door if that it what you need.
      thanks! which weatherstripping? the one that is to the outside of the door that touches the B pillar or the item that the glass moves against?
