ok so i installed my new clutch and flywheel about 4 weeks ago and the feel was nice and tight on the pedal but it slowly went down to were i have about and inch to a inch and a half of play in the pedal befor i can engage the clutch. While i tried bleed it i noticed that when you let the air out and are holding down the pedal as soon as the air is let out the pedal will drop to the floor? but it still has presure with play if you pull it right back up is this normal for it to drop down like that while bleeding it??
Please someone help me out its becoming really anoying while driving to work and back.
