I just got my car back from the shop today and they said they cannot reproduce the hesitation problem even though it does it to me all the time!
Problem: My '90 EX 5sp f22a4 will hesitate really bad at light throttle, especially when the engine is warm. If I keep it at light throttle long enough, it will make a rattling/popping sound and backfire. If I push the gas to the floor it will clear up. I have also noticed that if I start the car (with the engine still warm) and let it sit for a few minutes, the idle will drop really low, then kick up, then back to normal. After it does this, the car seems to do OK.
List of things I have already done to the car:
Replaced fuel filter, thermostat, spark plugs, plug wires, dist cap, rotor button, ignition module, ignition coil, and ECU.
I have no CEL and I jumped the connector to the ECU and it did not throw any codes.
I have used Lucas fuel system treatment and cleaned the throttle body. The only other things I can think of are the 02 sensor, distributor, or cat.
If anyone else has had these same symptoms or knows what the problem could be, any advice would be greatly appreciated.
