everytime i shift into 5th gear i hear this loud whirring sound coming from the engine and it only happens when i pop it into 5th (which isnt too many times). the tranny shifts fine and all the other gears are good with no noise this onoly happens in fifth gear...what could it be? im thinking its the tranny but what? it almost sounds like an intake sucking in alot of air but louder! any suggestions?
whirring sound in 5th gear
when i go from 4th to 5th it sounds fine...a perfect shift...just when i let the clutch out the whirring noise start right up...when i press the clutch back in it stops so i just drop back down to 4th and drive like that...i dont want to be driving at over 4k for too long...it spends too much gas especially with todays prices, i dont want to do that...im going to try the 3k rev that fizz says...if i do hear the whirring what does that mean fizz?
Originally posted by fizzbob7first off, don't be a sissy bitch.....that's what you're beingOriginally posted by ACC0RD22no need to get sand in your vagina over this guys.
Originally posted by fizzbob7what happens when you put your foot on the clutch all the way, while in 5th and cruising, but keep the engine revved up to around 3000rpm....does it still make that noise....
if it doesn't, then it may be the throwout bearing, although, it normally doesn't show up like this
