Ok. My check engine light would go on about once a month(for last year or so) but just for a split second. It would only happen around a certain turn, and when i was going very fast(between 40-50 around sharp turn). the light would just FLASH on for a second, and then dissapear.
Just tonigh, while testing my abs system(just changed abs reservoir) i did a very hard break from about 75 mph. When i did this my check engine light came ON AND STAYED ON. Being caught up in the moment(thinking like a total f'ing idiot!) i pulled over and turned off the car, and restarted. Of course the light stayed off.
(if i were smart i would have simply checked the code before turning the car off, but i'm a dumbass, and now i'm freeking out because i have no clue as to what is doing this)
So do you guys have any clue as to why my light goes on during sharp turns/brakes?
THANKS A BUNCH GUYS>
