how do i fix this code. my car wont start and i pulled a code 20 wich is the eld. where is it.
HELP code 20 (electric load detector)
hmm that stinks
eld is built into the fuse box under the hood. its on the right passenger side upper corner which houses the main fuse relay and other stuff. i dont know of any way to partially remove it or replace it but to replace the whole fuse box from a junk yard. your car wont start because it governs things like fuel injection, and charging system, as well as other stuff. if your eld is really bad then you battery may have discharged as a result so that may need to be chraged when you replace the eld. just make sure there is no blown fuses in your dash fuse box or something simple as i'd hate to see you replace an item if it not necessary. hope it helps.
oh and for future advice get a chilton or haynes manual cuz it has alot of info you should know.plus it help in finding your info faster. cost about 15 bucks from local autoparts store or even barns and noble. lata kid
