when i hit small bumps in the road and brake
    I think something is going terribly wrong with my steering...my car is lowerd with kyb agx and eibach sportline springs....i have a full camber kit....well anyways when i hit small things in the road like bumps my steering like jumps the opposite way of what it hit.........also it clicks once when i steer to the right when im sitting still
    also when i brake.......the car steers to the left
    Im thinking its a combination of alignement issues and brake alignment..if there is such a thing.........
    might be the rack and pinion...is it aligned properly?
    Originally posted by fizzbob7
    Originally posted by ACC0RD22
    So. Cal OUTLAWZ
      alignment,
      and im sure something bought the 1/2 shafts or joints. cuz when it clicks its bad.. just like my car. it pulled mad right..
      hahahahah
        check the camber kits...one of mine were broken when they started to pull and stuff.
        I <3 G60.
          you should jack up the front of the car and check for loose suspension components....balljoints, inner and outer tie rods, upper ball joint, upper control arms. also you should check the stabalizer links for cracked or missing bushings. it might not be a bad idea to check the wheel bearings either. also mis adjusted toe or camber could cause the darting like action you are describing.
          http://www.cb7tuner.com/vbb/showthread.php?t=22013
          cb7tuner.com Cleveland division
            hey let me know what you find, im stock right now but am going to lowering shortly, and i am experiencing a little bit of bump steer too.
              that is a sign that mayb ur rotors are warped? that it is grabbing.? i had a problem like this and i caused a nauseating smell like burnt rubber made my steering wheel all shaky .
                well my rotors are warped, but that only is noticeable when braking moderately, this other lightness of the steering wheel and bumpsteer happens over some bumps
                  i found the freakin problem!!!
                  hello...the problem and the reason why my car was moving to the left and changing directions when i hit speed bumps..was a bolt was missing from my rack and pinion mount...........i think once a car gets lowered and it has so many miles..you gotta check important ish like that..more bumps..means stuff gets loose.......or i have a paranoid feeling one of these bad ass kids in my neighborhood did it...well the problem is fixed...now on to fixing my ..do they have to take my rack and pinion off when they install my suspension??..that might have been the problem..this shop did a shitty job!! light.........4TH GENERATIONS ARE THE BEST LOOKING!!!!
                  i have kyb agx and eibach sportlines with full camber kit all the way around....nice ride!!!...
                    Ummm................what? That last part seemed like some kinda random rambling.
                    Fix your Computer!
                    Originally posted by MikeW
                    D, I'm a fanciful motherfucker. My ish is clean, quick, plush, mature and sophisticated.
                    ಠ_ರೃ
