problems with radiator aswell as cooling systems
    Okay my car overheats just a tad bit. This shit is pissing me off becasue my radiator has little metallic flakes in it im not sure weather it needs to be flushed but somehow i think its not flowing properly. Ohwell has anyone else had these symptoms.
    thats not good that it has flakes, maybe from water pump?? going bad?
    hahahahah
      yeah sparkle lil flakes not a good look flush it then see if there any flakes left if so i would say the water pump also i remember i had a corolla like that and it was the pump but then again u got the turbo
      LEAVE NO DOUBT!
      If God is for Me
      Who Dares be aganist Me!
      BX Crew
      HSHO # 6
      Lexotic Concepts 019
        flush it dude, that might help and/or check your water pump
        Audi A4 2.8 Quattro Sport
          My h2o pump took a shit, and the symptoms were overheating while being stopped and cooling down while moving at above 30mph.
          Also, I didn't see any radiator fluid moving across when I opened the cap, and I even poured more in there but I'm assuming a bad pump would not allow it to flow at the top.
          '93 Bordeaux Red Pearl LX 5MT
          Prev CBs:
          -'93 BRP LX 4AT
          -'92 AGP LX 5MT
          -'93 AGP EX 4AT
          10yrs after my first cb, I'm still driving one!
            Also, just to confirm sparkle, you're using a Civic style "half radiator", I'd assume a slim-fan of some sort, and you do not have the thermostat in. Correct?
            I'd say flush out the entire system and go from there first.
              i do have the thermo in
                Yeah, drain all the coolant, fill her up w/water, circulate it for a minute.. drain that, and to be safe, do it again. Then refill with coolant/h20 and see what happens. Is the rad new? and how old is the water pump? I saw somewhere someone had a picture of a water pump, and the fins were completely corroded away. Are the flakes more silverish or goldish? I know the water pump is more goldish in color.
