Hi all. I have a problem that I'm hoping to get fixed soon. I have a 92 jdm accord with a h22a swap. Auto to manual swap was done at the same time. The problem is when I take off from first and when I change gears sometimes I get a squeek that sounds like tyres losing traction. It is quite loud, easily heard from cars around me. It seems to happen when the clutch is slipping before fully catching.
I'm pretty sure it's gearbox related as like I said it happens when changing gears aswell. I bought the car recently and it supposedly has a 5puc brass button clutch aswell. I have had two mechanics suggest things like the thrust bearing, sprocket bearing??, or even just the clutch is buggered (it's supposed to be fairly new).
Has anyone had a similar problem? Do any of these sound like the culprit? I will get more mechanics to have a look before heading straight for a clutch swap as this would be pricey. thanks for any suggestions if more details are needed I will try and describe it more.
